TwinTurbo.NET: Nissan 300ZX forum - Re: Relicating knock sensor... M8-1.25 x 90mm Correct size ?
nonstopna
on March 18, 2015 at 4:38 PM
posted by nonstopna
on March 18, 2015 at 12:07 AM
What do u guys think of a 95mm hex bolt? I figured the head will seat on the top of the sensor nicely instead of the plastic and likely not bottom out. I'll have to measure once I get the bolt and post results and pics.
nonstopna
00:07:28 03/18/15
Use the 100mm....
Zuberman
00:44:21 03/18/15
Unless you want to do the math of subtracting the nut in
Zuberman
00:50:29 03/18/15
Well ... I'll just go with the 100mm.
nonstopna
01:54:14 03/18/15
Re: Well ... I'll just go with the 100mm.
ttz'in (norcal)
01:57:23 03/18/15
Goldchocobo
12:48:24 03/18/15
2nd. I used my inch-lbs torque wrench to make sure I didn't
Zuberman
13:01:23 03/18/15
Re: Relicating knock sensor... M8-1.25 x 90mm Correct size ? -
nonstopna
16:38:35 03/18/15
Sounds good.. (n/m)
ttz'in (norcal)
20:19:39 03/18/15
